MapViewTapped invalid location DPI problem
918
7
08-24-2016 02:46 AM
AlexKost
Hi, I'am using ArcGIS  SDK for .NET 10.2.7.0 and creating "modern" store app (Store API) for Windows 8.1.  I have problem with DPI changes. On some monitors (Full HD, 24 inch, 100% scaling in Windows 10) returns MapViewTapped event correct location, but on some monitors (Full HD, 15 inch, 150% scaling) returns wrong location (several cm from correct position on Map).
AnttiKajanus1
Occasional Contributor III
Unfortunately this is a bug in Windows 10 when running Windows Store 8.1 apps in different DPI settings. We have submitted support case to Microsoft for it. I'll have a look if we have update for this.
AlexKost
Thank you, is there some workaround? With pixel to coordinates ratio and real click point?
AlexKost
I found some workaround:
public async void OnMapTouch(object sender, MapViewInputEventArgs e)
   MapView view = sender as MapView;
   MapPoint mapPoint = e.Location; //clicked coordinate, not works on some DPI/DPI changes
   double unitPerPx = view.UnitsPerPixel; //not works on some DPI/DPI changes
   double unitPerPx_real = view.Extent.Width / view.ActualWidth; //it seems to works
   double x_offset = e.Position.X * unitPerPx_real;
   double y_offset = e.Position.Y * unitPerPx_real;
   Viewpoint viewpoint = view.GetCurrentViewpoint(ViewpointType.BoundingGeometry);
   double x = viewpoint.TargetGeometry.Extent.XMin + x_offset; //x coordinate, seems to works
   double y = viewpoint.TargetGeometry.Extent.YMax - y_offset; //y coordinate, seems to works
Update:
But other functions, as mapView.Editor.RequestShapeAsync not works
AnttiKajanus1
Just an idea what to test. You could override editor progress and fix the geometry in the event.
AlexKost
I tried this:
var progress = new Progress<GeometryEditStatus>((status) =>
   / /never called
Esri.ArcGISRuntime.Geometry.Geometry newGeometry = await mapView.Editor.RequestShapeAsync(Esri.ArcGISRuntime.Controls.DrawShape.LineSegment, null, progress);
But progress delegate is never invoked during drawing
AnttiKajanus1
Ah, line segments doesn't have events since it's only one action. Ie. Polygons would raise the event. I take that the only way to fix LineSegment is to iterate through the Points collection and fix all the points. Not very convenient but might do the trick.
AlexKost
Thank you, I solved it by own drawing to Canvas and pixel -> coordinates workaround from former post.
