Load a Scene from the Portal
1048
08-24-2016 12:56 PM
AliBensaid
Hi guys, I'm trying to load and show a Scene that I created on my Online Portal. I am currently able to load WebMaps using the WebMapViewModel class, but I can't find any way to load a Scene from the Portal directly ? Is there any way to do this ? Do I have to take the layers and add them to a local Scene manually ?
Thanks !
Ali
AliBensaid
Hey guys, it's me again.
After messing around a bit I found out that Web Scenes can be loaded through the WebMap.LoadFromPortalAsync method. But anytime I have a 3D layer on the Scene, I would receive an exception in that method concerning a "simpleRenderer" JSON deserialization issue. Does anyone have this issue or is there a fix/workaround to show 3D layers on the MapControl ?
Thank you for your answers
Ali
AnttiKajanus1
Occasional Contributor III
I think that WebMap is working with a Map (2d) and not with a Scene (3d). Also note that when you are working with 3d data, you need to use SceneView (with a Scene).
You should have two options here:
1) Create SceneView and Scene manually in code
2) Build your own deserialization from JSON that is returned from ArcGIS Portal Item and construct the Scene from that.
