Variable width buffer along line
3346
9
08-24-2016 01:31 AM
BartoszBrzeziński1
New Contributor III
Hi everyone!,
i`m using Arcgis Desktop 10. 4 and i`d like to somehow obtain even distribution of value along line. I have river line. At the beginning of river section value is 3 meteres, at the end 6 meters - random values to present issue. Is it possible to get even distribution along that section? Thanks for help.
DanPatterson_Retired
Can you clarify... you have shown a start and end line, perpendicular to the river... are the lines to be spaced with an increasing length and constant spacing?
BartoszBrzeziński1
New Contributor III
Lines presents start and end of section but also places where buffer should start with 3 meters width and end with 6 meters width. Next image should explain this better.
BartoszBrzeziński1
New Contributor III
 The result. Nice tool but it works for just only straight lines.
ahh... should have used that as your example photo...
check Darren's example and see it handles inconsistent angles... can't remember, but I am sure the code could be modified for your situation
https://community.esri.com/message/622726
BartoszBrzeziński1
New Contributor III
Thanks once again but i have no experience in Phyton.
BartoszBrzeziński1
New Contributor III
Could you help me with that code?
I'll let Darren Wiens‌ fill in the final code, but these need to be changed as well as giving file paths instead of the in_memory locations
lines = r"c:\temp\myline.shp"   # or r"c:\temp\some.gdb\myline"
max_buff = 50 # buffer at line start
min_buff = 10 # buffer at line end
if it works... you save the result
JayantaPoddar
MVP Esteemed Contributor
There should be better methods than the following.
Make a copy of the line feature before following the methodology. Also the layer/data frame should be in Projected Coordinate System with map unit in meters.
1. Cut and delete any unnecessary portion of the line for which you don't want to create the buffer.
2. Split the line into n equal parts. The more number of parts you create, the smoother output you will get (say you divide it into 60 parts since it is a multiple of 3).
2. Add a field (Float) to the attribute table for the buffer distance. Fill the attribute values using Attribute editor in regular intervals like 3, 3.05, 3.1, 3.15,....., 5.9, 5.95, 6. (Tedious task I know).
3. Create buffer based on the above Field.
Think Location
