ArcGIS for Server 10.2.2 javaw
2602
15
08-25-2016 12:41 PM
DaveTenney
Occasional Contributor III
does anyone know of any major issues with ArcGIS for Server javaw consuming massive amounts of memory and almost bringing down an entire server instance?
thanks
dave
JonathanQuinn
Esri Notable Contributor
There is a bug at 10.2.2 that's resolved with a patch:
ArcGIS for Server Security 2016 Update 2 Patch
BUG-000082423 - Under consistent load, the javaw.exe process at ArcGIS 10.2.2 for Server consumes 25% of the server's RAM, and any further request forces the process to use 100% of the machine's CPU.
Do you have this patch installed?
JonathanQuinn
DaveTenney
Jonathan,
    thank you so much for the help, will get this patch in place ASAP!
do you know if this bug was fixed in 10.3.1?
thanks again
Dave
JonathanQuinn
Yes, it does appear to be fixed at 10.3.1.  Definitely install the patch, hopefully it'll help.
JustinWhite2
We are seeing similar behavior in 10.4.0 (build 5524): javaw.exe (with logging on the command line) taking 70-90% of the CPU (it climbs over time but seems to start @ 70%) and 2.5GB of memory (which is not really a big deal). We are running VMWare and have around ~60 services. I recently took over the server and honestly am unsure of how long it has been doing that, although there haven't been any major changes, that I know of, recently.
Rebooting seems to fix it for a couple of hours and then it starts again. From what I can tell, there is nothing in the error logs that coincides with the problem starting.
Has anyone seen something similar or is there a fix or a patch?
Thank you!
Justin
DaveTenney
Justin,
   i would be very interested in knowing if you figure out more....
if you see above, this issue was supposed to be fixed in 10.3x, and was supposed to be fixed in 10.2.2 with their recent security patch. We have installed the patch for 10.2.2 i have noticed some spikes still...upwards of 2gb of memory, after patch was installed and machine was rebooted.
please keep us updated.
dave
JustinWhite2
Will do Dave - thanks for the additional info!
Justin
JonathanQuinn
Regarding the javaw.exe processes, RAM usage increasing isn't a problem as long as it stays lower or equal to 25% of the available physical RAM on the machine.  The main problem is the CPU usage which shouldn't happen even if the RAM usage is at at 25% mark.  It'd be useful to get a better understanding of load on the server before and during the time that your CPU is at 70-90%.  Is the Server handling at lot of requests at that time?  If so, what type?  Export map requests, GP services, etc.
JustinWhite2
Thanks Jonathan!
The server load, in my opinion, is not over the top but I could be wrong as I am not entirely sure what constitutes a large load on ArcGIS server (sorry, I am new to the admin side of ArcGIS Server - long time developer). I have uploaded an image of the last 30 days on our server to give you an idea of what our usage looks like.
Our services are almost entirely pre-cached (the cache is built on a different server) Map Services and a couple of Dynamic and Editable Map Services and a handful of Image services. We are also running ArcGIS Portal on this server and access it via AGOL. I have confirmed that the copy of javaw.exe that is giving us the problem is the version running for ArcGIS Server not Portal.
Our logging was previously set to warning, although I have bumped it up to Fine to try and determine if there is a specific service causing the issue. It honestly appears to be irrespective of use (although I have nothing empirical to prove this) and the CPU usage just grows over time.
We have gone through our service catalog and shutdown about 25% of the services that were running but no longer being used and I will wait to see what happens with a restart. I am totally open to suggestions on how to collect more data or try and fix things. Also totally open to opening a support ticket.
Thank you again Jonathan - much appreciated!
Justin
30 day usage
JustinWhite2
Quick update: I believe I have tracked down the culprit. It appears to be Google bot requesting kmz files for our services that is driving the CPU usage on the javaw.exe process through the roof. Interestingly enough, some of the links were throwing ASP.NET errors and I was able to perform a reverse DNS lookup of the IP to trace the request back to Google. From there I was able to repeatedly call the kmz request URL from my browser and watch the CPU usage climb by 10%, even for a request that didn't throw and error and actually returned the KMZ.
Jonathan - is there a way to disable KML/KMZ downloading? The KML checkbox in the "Select and configure capabilities" section of "Capabilities" in the Service edit screens is not checked, yet it still allows downloading the KMZ. Or perhaps somewhere I can put a robots.txt file to tell Google to stop trolling our services? Or??
As it stands I feel pretty good that this is the culprit, but like all troubleshooting of this nature, I could be wrong...
I apologize as I feel like I have sort of hi-jacked this thread and that wasn't my intent!
Thanks for reading,
Justin
