lidar LAS data Clip
2247
08-25-2016 02:16 PM
DanielKim3
Hi there,
I would like to find out if there is a way in ARCGIS to clip LAS dataset with my polygon shape.
Your help would be appreciated.
Tags (1)
DanPatterson_Retired
you can in PRO Extract LAS—Help | ArcGIS for Desktop
and in 10.4 Extract LAS—Help | ArcGIS for Desktop
below this, you are due for an upgrade
AdrianWelsh
MVP Honored Contributor
Daniel,
It looks like there is some information here, in addition to what Dan has posted:
https://community.esri.com/thread/76092
Though I would think that Extract LAS would do what you need.
NeilAyres
This item
rearrange_points
(Optional)
Determines whether to rearrange points in the LAS files.
  • REARRANGE_POINTS —The order of the points in the LAS files will remain the same.
  • MAINTAIN_POINTS —The points in the LAS files will be rearranged. This is the default.
Boolean
in the help, seems to be the wrong way round.
