Publish from ArcGIS Pro to ArcGIS Server?
1828
5
08-29-2016 08:39 AM
AngeletaWilson
Can I publish from ArcGIS Pro to ArcGIS Server? I have been trying to add the link in Pro but it keeps giving me an error - Unable to establish a connection. Need to figure out if it is a firewall issue or if it that it just can't be done. Haven't been able to find documentation, so I am assuming it is the latter?esriforumuser
DanPatterson_Retired
Is this related? Publish from ArcGIS Pro
AngeletaWilson
"Share"
or some other "Share"
AngeletaWilson
Sorry, that "share" was an error and couldn't figure out how to delete...
OK, from the documentation, I found this " server_type - A string representing the server type. Currently, the only supported value is MY_HOSTED_SERVICES for ArcGIS Online. (The default value is MY_HOSTED_SERVICES)"
So that answers my question. Thanks for your help! Not sure why @ESRI would do this...
AngeletaWilson
I will try this and let you know if that works. Thanks!
