Relevant field checking if previous question has been answered
3561
5
08-29-2016 09:06 AM
AndyKeljarrett
New Contributor III
Just wanted to check if anyone knew how to make a question / section only appear once a question has been filled in? In this instance I don't mind what answer has been put in, only that an answer HAS been put in. I had managed to do this but have since accidentally deleted the relevant XLSForm
Andy
IsmaelChivite
Esri Notable Contributor
Did you try ${PreviousQuestion} !='' in the Relevant column?
AndyKeljarrett
New Contributor III
Works brilliant for text etc questions. What if I want to check if a Geopoint question type has been filled in?
SeanEdwards
Ismael, I'm wondering if this relevant works with dates. I am calculating "Days on Assignment" by subtracting ${Date2} - ${Date1} with ${Date1} a required field but not ${Date2}.
I have figured out the calculation but cannot figure out how to hide ${DaysOn} unless ${Date2} is selected.
Date1 and Date2 are type date and DaysOn is an integer.
Cheers!
IsmaelChivite
The safest way to figure  if a question is empty is to use string-length. For example: string-length(${Date2})>0 in your relevant column for DaysOn will hide DaysOn unless Date2 has been answered.  string-length works well with all types  of  XLSForm questions.
SeanEdwards
Thank you Ismael, that worked perfectly.
