Adding values to dijit/form/ComboBox
3566
08-29-2016 04:03 AM
MargaRaiz
New Contributor III
Hello!
I am learning wab and dojo and trying to load some values in a combo box that is defined in the widget.html:
widget.html:
           <select data-dojo-type="dijit/form/ComboBox" id="listcity" name="citycombo"> </select>
widget.js:
              node = dojo.byId("listcity");
              var elOptNew = document.createElement('option');
              elOptNew.text = "city1";
              elOptNew.value = 1;
              node.add(elOptNew);
              elOptNew.text = "city2";
              elOptNew.value = 2;
              node.add(elOptNew);
This works fine for me, but I think that there are other ways with the stores to do the same.. Any help?
Thanks in advance!
Marga
RobertScheitlin__GISP
Marga,
   When you use widgets in the html template you must include the require for _WidgetsInTemplateMixin and declare it as well in the Widget.js. You also need to require the specific dijit or widget that you are including in the template:
Widget.js: (lines 3,6,7,9)
define(['dojo/_base/declare',
'dojo/store/Memory',
'dijit/_WidgetsInTemplateMixin',
'jimu/BaseWidget',
'dojo/dom',
'dijit/form/FilteringSelect'],
  function (declare, Memory, _WidgetsInTemplateMixin, BaseWidget, dom) {
    //To create a widget, you need to derive from BaseWidget.
    return declare([BaseWidget, _WidgetsInTemplateMixin], {
      // Custom widget code goes here
      baseClass: 'jimu-widget-mywidget',
       startup: function() {
        this.inherited(arguments);
        //this.mapIdNode.innerHTML = 'map id is:' + this.map.id;
        console.log('startup');
        var cities = [
            value: 1
            value: 2
         myStore = new Memory({data: cities});
        this.cityCombo.set('store', myStore);
        console.log('end');
Widget.html:
<div>
  <div data-dojo-attach-point="cityCombo" data-dojo-type="dijit/form/FilteringSelect"
   data-dojo-props="searchAttr:'name',intermediateChanges:true" class="dijit-form-FilteringSelect"></div>
</div>
Marga,
   All you need is to add the necessary requires and code:
Widget.js
 function(
Memory,
var cities = [
    value: 1
    value: 2
    data: cities
this.citycombo.set('store', myStore);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Widget.html
MargaRaiz
New Contributor III
Hi Robert!
Thanks for the quick answer, but this piece of code does not work 😞
Widget.js
'jimu/BaseWidget',
'dojo/dom'],
  function (declare, Memory, BaseWidget, dom) {
    return declare([BaseWidget], {
        var cities = [
            value: 1
            value: 2
        console.log('end');
widget.html
but.. when I tried from my app, I get this error in de firebug..
TypeError: this.cityCombo.set is not a function
I have tried with "put" function, with "dom.byId" but I am not able to make it works.
Any idea?
Thanks!
Marga
Marga,
'jimu/BaseWidget',
'dojo/dom',
        var cities = [
            value: 1
            value: 2
        console.log('end');
Widget.html:
<div>
</div>
