Can a previous survey results display in your current survey?
1096
08-31-2016 07:20 AM
JohnMcConalogue
New Contributor III
If I carry out a survey now can I go back and update the results of that survey in a months time if what I am surveying has changed?
Thanks.
MarikaVertzonis
Update the same record in your existing feature service - no, but use the data collected previously to create a new record - yes.
In version 1.7 you can use the XLSForm function pulldata() to extract data for your survey from a provided CSV file. For more information see
https://community.esri.com/groups/survey123/blog/2016/09/01/international-day-against-nuclear-tests-...
JohnMcConalogue
New Contributor III
Thanks for the reply Marika but I already have that information.
It seems that the XLSForm function pulldata() is just pulling the data from a static CSV file and referencing it in calculations in your survey. What I want to do is load the CSV data into the survey results i.e. the Database or wherever the results of surveys are stored.
anyone know how to do this?
