Manage spatial data using PL-SQL
1466
5
09-02-2016 12:14 AM
testtest7
How can I copy a feature from a feature class table to another? I can not see the feature when I use select insert statement.
JoshuaBixby
MVP Esteemed Contributor
You haven't given us much to go on.  For starters, it would help to see your SQL or some representative SQL.  Also, some basic information about the database, or is it a geodatabase?
testtest7
I have a feature class , its shape type is numeric(38). I would like to copy feature from one feature class to another using SQl
insert into FeatureA(a,shape) select (a,shape) from FeatureB;
But only shape field will null after use the SQL
JoshuaBixby
What backend DBMS are you using?
testtest7
oracle 10G
