Attribute Query using Model Builder
1365
09-06-2016 10:38 AM
akshayloya
Occasional Contributor II
Hi Everyone,
I want to create model in arcmap using model builder for select by attribute.
1) I want to create a dropdown list for columns fields of the selected feature class
2) Write a dynamic sql expression as in:
   a) User will select column name from the drop down.
   b) User enters a value in a value box
  c) At a back end, SQL query is made based on above selection.
Example: Select Features from School feature class having objectid >= 6 AND objectid <=  15.
This is simply to make attribute query easy to use for the user. Any help will be greatly appreciated.
Thanks in Advance!
DarrenWiens2
MVP Honored Contributor
Your example (objectid >= 6 AND objectid <=  15) illustrates the problem with using rigid dropdown lists to build SQL queries. It includes (or could include) multiple fields, operators, and a condition. You could make dropdowns for all of those, but how is that any better than the out-of-the-box query builder within the Select Layer By Attribute tool?
akshayloya
There will be only one condition mentioned above (between) and the same operators will be used. So I don't want user to select all those options. He will simply select field from a dropdown and in to boxes he will enter the value.
Please refer to pic below.
