GeoEvent Extension istallation
1478
09-07-2016 01:05 AM
DEVAPP
New Contributor III
Hi att all,
i have to install the GeoEvent Extension. reading the guide lines the GeoEvent Extension should be intall o a separe server, but i have one server and so i must to istall on the same server that have ArcGIS Server.
I have seen that GeoEvent Extension work in https protocol, so my question is:
the machine where i will install GeoEvent Extension must be in https protocol?
Tags (1)
AlexanderBrown5
Occasional Contributor II
Dev,
You must have ArcGIS Server configured for https protocol.  There are various options, whether that is utilizing a self signed certificate, domain certificate, or a CA certificate.
Configuring HTTPS using an existing certificate—Documentation (10.4) | ArcGIS for Server
Configuring HTTPS using a new CA-signed certificate—Documentation (10.4) | ArcGIS for Server
Configuring HTTPS using a self-signed certificate—Documentation (10.4) | ArcGIS for Server
Optional: Replacing the ArcGIS GeoEvent Extension for Server self-signed certificate—Installation Gu...
Optional: Marking the self-signed ArcGIS GeoEvent Extension for Server certificate as trusted by Int...
You must go to http://gisserver.domain.com:6443/arcgis/admin and switch security to http and https or https only for your ArcGIS Server site.
For example, if you create a domain certificate in IIS, you can then import that into ArcGIS Server and GeoEvent.
Read over the documentation above and it should point you in the right direction.
~Alex
DEVAPP
New Contributor III
Hi Alex,
thanks for your replay. I know the https configuration for ArcGIS Server, but i must set only https or i can set a mix protocol? http / https? More external web app read the AGS Service in http.
AlexanderBrown5
Dev,
You can set mixed protocol (http/https) or https only.
~Alex
