Replicating a Table
1420
09-07-2016 07:07 AM
JoeBorgione
First:  ArcGIS Server / Enterprise GDB 10.3.1 with Sql Server 2012 back end.  ArcGIS Desktop 10.3.1.
There are a couple of discussions related to my issue ( see: Non-spatial table replication  and https://community.esri.com/thread/111346 ) but they are with check out replicas.  My problem is when I replicate a non-spatial table from an Enterprise gdb parent to a file gdb child using Oneway Replication, the initial replicated table is empty.  My work around is to add a short integer field to the parent prior to replication.  Then I create the replica.  Then I go back to the parent and update  the short int field = 0 and sync. Since everything has changed, all the records come over.
Is this expected behavior for a Oneway Replica for a non-spatial table?
jskinner-esristaff
ASenGupta-esristaff
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Joe,
When you are creating the replica, are you clicking the dropdown and selecting 'All Records'?  Ex:
You will need to check the option 'Show advanced options for overriding replica defaults when I click Next' to see this option.
JakeSkinner
Hi Joe,
JoeBorgione
For hecks sake, that was easy.
Thanks Jake !
#replication
JakeSkinner
Not sure why that's not the default, but I believe there is an enhancement request for this, and there is also an ArcGIS Idea:
https://community.esri.com/ideas/3541
JoeBorgione
Noted and voted....
