NIM038965 : Slow opening of MXDs due to old connection information
1577
5
09-12-2016 03:37 PM
TodStevens
Does anyone have a workaround for this 2008 defect? I have tried all the proposed python and mxddoctor solutions without luck. Inserting entries into the hosts file for old server (actually a server in a different domain) works but is not allowed in the government production environment.
The MXD still contains old arcgis connection information and thus when opening the MXD you suffer a delay of up to 50 seconds.
Many Thanks.
Synopsis
Map documents (MXDs) preserve the layers' old server information after resetting the data source, which causes slowness in opening the documents if the older server is taken off the network.
DanPatterson_Retired
That NIM doesn't show up on support Esri Support Search-Results  using any incarnation of searches.  Do you haver a direct link?  Perhaps because of the 2008 date, other workarounds have been provided, or legacy projects require an upgrade.  Since it is government, I would be surprised that a solution hasn't been proposed, even if it wasn't acceptable to your IT department.
TodStevens
Hi Dan
http://support.esri.com/bugs/nimbus/TklNMDM4OTY1
Regards
Tod
I think ... Not in Current Product Plan ... indicates the status, probably because it affects only a few.  I would recommend contacting tech support to see if any alternates to the alternative solution have been reported by others.  I am also not sure what ... No Public Explanation... means, perhaps there are some disclosure issues around it.  good luck
ChristianWells
One workaround we have seen to work is to re-generate the MXD's via Python. You could try the following script here:
developer-support/refresh-mxd-layers.py at gh-pages · Esri/developer-support · GitHub
This will take a folder of MXDs, move them to a blank MXD and then save to a new folder.
It could be worth a test on a handful of MXDs
JayantaPoddar
MVP Esteemed Contributor
You could try disconnecting the client from Network > Open the MXD (Is it opening faster?) > Connect to the Network > Repair the Data Source.
Think Location
