Add outcome layer of modelbuildder to the current ArcMap window
1355
09-14-2016 07:11 AM
LanoYado
New Contributor III
Hello, I wondered if there is a way to add the outcome layer resulted by modelbuilder to the current window like when you use any tool out of modelbuilder.
Thanks in advance
DanPatterson_Retired
did you check you arcmap settings under display and temporary data?
JayantaPoddar
MVP Esteemed Contributor
Right-click the Final output > Add to Display.
Displaying Model Data
Think Location
LanoYado
New Contributor III
Thanks all
by Anonymous User
Not applicable
After running the model in Arc Map in result tab you can choose or select display/add result in TOC
And you can also include or mark to add result in TOC from model output
