Network Dataset Help
1267
8
09-14-2016 11:47 AM
CadAssistant_3
I am working on a network dataset for my campus. I have loaded all the locations as "stops" but I've been trying to figure out how I can find routes between two Stops, given that I have about 90 something of them. Thank you. am working on a network dataset for my campus. I have loaded all the locations as "stops" but I've been trying to figure out how I can find routes between two Stops, given that I have about 90 something of them. Thank you.
DanPatterson_Retired
what is the purpose?  Given your dataset, I don't think you really want or need the route or travel time between all of them ... for example stop 8 and 9 ...
CadAssistant_3
I am just trying to find the shortest distance route between two different stops. I guess my question would be, when I want ArcMap to solve from which two points I want a route from how do i specifically tell ArcMap for example, I want to get from from stop 8 to stop 17?
CadAssistant_3
Yes that is correct from C_Path. I am also looking for shortest distance, not dealing with time just yet. I know how to manually place down to different stops and then "solve" for a shortest distance route, but now that I have loaded about 90 stops how can I choose which two stops I want a route for. As an example, I want to tell ArcMap to get me a route from stop 9 to stop 23.
JoeBorgione
Add your stops feature class to your ArcMap session.  Select the two you wish to analyze.  In the Network Analyst Route Window Pane, right click on Stops and Load Locations.  Just be sure to check the Select Features option.
CadAssistant_3
Ok so if I am understanding correctly, I can not load my stops feature class into "Stops" in the network analyst and then choose different stop locations I want a route created for?
CadAssistant_3
If you refer to the image I attached to this thread it shows my stops feature class called (building entrances) loaded as Stops in the network analyst.
did you select with the available stops?
JoeBorgione
I'm guessing the C_Path_Routing (edges) are the Network feature dataset edges built from the C_Path, correct?  What are you trying to optimize in your routing solutions?  Is it Time?  Is it Distance? Your edges need to be attributed in such a fashion that they can provide you with the solution you are looking for.  As an example, if you are trying to find a route that minimizes travel time between stops can you calculate that with the data you have?
