Robert, Can you please share the eSearch widget (older web builder 1.3 version) which has the export URL option working?
Sonia
Solved! Go to Solution.
Sonia,
You are using WAB Version 1.3 and eSearch 1.3.0.2 and you are using a unique value for your search this did not work in 1.3.0.2 but was since fixed in more recent versions. If you use WAB 2.1 and the latest eSearch then you will no have any issue. Also you have to have your eSearch widget loaded at start for the url search to work.
Sonia, the export search url works in all versions of eSearch. You have to change the settings to enable it. Also you will see in the help document that the export does not work until you deploy the app to your web server.
Thank you so much Robert.
Sonia,
Thanks Robert!
Sonia,
It looks like you have stumbled across a bug that I will fix in 2.1.2 version (hopefully I will release today).
Thanks so much Robert!!!
Sonia,
Version 2.1.2 of the eSearch is now released.
