How to find point on the line from nearest point
1848
09-21-2016 05:42 AM
JurateMeister1
I am trying to find the coordinate of the line at the nearest distance from the point. I am using sde st_geometry library in oracle. I need the code that i can add to my pl SQL procedure.
Thank you, Jurate
JayantaPoddar
MVP Esteemed Contributor
You can use the NEAR tool. Keep the Location parameter checked. This will add two new fields NEAR_X and NEAR_Y to the attribute table.
Think Location
JurateMeister1
Yes, I know I can use arc toolbox and gp. I am trying to get this done directly in oracle using sde.st_geometry library
JoshuaBixby
With some other DBMSs, e.g., SQL Server and PostGIS, it would be fairly simple to use a shortest line method/function, if I understand your situation correctly.  Unfortunately, the ST_Geometry library doesn't offer similar functionality.  Doing some quick searches on "SQL nearest point" and "SQL shortest line," it appears there are a variety of suggestions, none of which I can speak to in terms of performance.
