Does REST API doesn't allow to retrieve blob fields?
1979
09-23-2016 04:10 AM
TomaszSt
Hello everyone! I have difficult problem - when I try to get JSON data from ArcGis REST API by query command all is working fine, but one field is a type of blob (esriFieldTypeBlob) which really contains image. Unfortunately, the rest api don't return that field (is not listed with returned values). I've found that someone wrote that arcgis rest does not handle that type of field, but some sort of applications (ie. collector for arcgis) use it and show blob properly, so it's must be available.
Is anyone know how to solve this issue? I'll be grateful for any clues. Thank you!
Haider_AliFaheem
I also have the same issue did you find any solution?
XanderBakker
Esri Esteemed Contributor
Maybe this Access data (Blob) | ArcGIS API for JavaScript 3.23  is a solution...
... or creating a replica into a FGDB and then use some Python as described here: How to extract feature service data with attachments enabled from ArcGIS Online — Esri UK
