Adding Line Barriers as NaLocations
1266
09-24-2016 11:41 AM
Haider_Ali
I cant figure out how can i specify line barrier in setPolylineBarriersByRef  of NAServerRouteParams class,
i know it takes INAServerLocations  but i cant figure out how to provide line in propertySet
IPropertySet line = new PropertySet();
line.setProperty("paths", polyline);   // cant figure out this
IPropertySetArray pPropSets = new PropertySetArray();
pPropSets.add(line );
//Setting the Server Property Sets for the Network Analysis
INAServerPropertySets propSets = new NAServerPropertySets();
propSets .setPropertySetsByRef(pPropSets);
INAServerLocations2 serverLoc = (INAServerLocations2) propSets ;
return serverLoc;
Tags (3)
DmitryKudinov
Hi Haider,
The GISClient API you are referring to is deprecated since version 10.0. If you still have to use it, the following snippet may help:
protected INAServerPropertySets GetPolylineBarriers(int numberOfLocations2Load, double[] candidates)
  /* Assumes that candidates is an array of doubles
  * which contains 3 vertices (6 double numbers) per polyline-
  * 3 * (x, y)
  INAServerPropertySets res = new NAServerPropertySetsClass();
  res.PropertySets = new PropertySetArrayClass();
  for (int i = 0; i < numberOfLocations2Load; i++)
    res.PropertySets.Add(new PropertySetClass());
    res.PropertySets.get_Element(i).SetProperty("Name", "Polyline " + (i + 1));
    IPolyline pl = new PolylineClass();
    IPointCollection pcol = pl as IPointCollection;
    object missing = Type.Missing;
    for (int j = 0; j < 3; j++)
      IPoint pnt = new PointClass();
      int xIndex = i * 6 + j * 2;
      pnt.X = candidates[xIndex];
      pnt.Y = candidates[xIndex + 1];
      pcol.AddPoint(pnt, ref missing, ref missing);
    res.PropertySets.get_Element(i).SetProperty("Shape", pl);
  return res;
On the other hand, if you are using a newer version of ArcGIS Server I strongly recommend using REST API instead:
ArcGIS REST API
DmitryKudinov
Hi Haider,
  * 3 * (x, y)
  return res;
ArcGIS REST API
Haider_Ali
Thanks that worked, i.e. line.setProperty("Shape", polyline);
Actually our requirement is to get multiple alternative route  , so our solution was to use SOE to avoid multiple call to server i.e. in the SOE find the route and provide that route as barrier for next  solve route.
