WAB application created on Windows fails to open on a Mac
1455
09-25-2016 06:45 PM
StephenLead
Regular Contributor III
Should it be possible to run a Web AppBuilder application on a Mac?
  1. I'm using the Developer edition of WAB on Windows 7 to create a simple WAB application
  2. I Download the application from WAB and put it in the Windows machine's /inetpub/wwwroot/xyz folder
  3. the application works as expected when accessed via http://localhost/xyz  on the Windows machine
  4. I zip up the application and copy it across to a Mac which is running Apache, and put it in the /Library/WebServer/Documents/xyz folder
  5. the application fails to run on the Mac, with multiple 404 errors:
404 errors
eg: http://localhost/http://localhost//jsapi/jsapi/dojo/resources/dojo.css Failed to load resource: the server responded with a status of 404 (Not Found)
Why is the path referencing localhost twice (http://localhost/http://localhost//jsapi/)? Note that this doesn't occur on the Windows machine.
Is a WAB application supported on a Mac? thanks
QunSun
by Esri Contributor
Hi Steve,
I guess you don't set apiUrl manually. If so, WAB will calculate apiUrl automatically.
Mostly, when you deploy the app, you should set apiUrl in env.js as the following screenshot.
Have a try.
RobertScheitlin__GISP
Stephen,
   Are you using a local install of the JS API in your web app?
StephenLead
Hi Robert,
No, it's a vanilla WAB installation and a simple application with nothing fancy in it. The strange thing is that the identical code works on Windows, while failing on the Mac.
It's not a big deal as I can run it on the Windows VM on the Mac, so I guess I'm just curious as to why it doesn't work there.
Steve
QunSun
by Esri Contributor
Hi Steve,
Have a try.
LibertadChapinalC
Hi!
This error has also happened to me on windows!
QunSun's solution worked for me but I've seen that code is commented only if you copy the app from the server/apps folder. However, if you download the app of the WAB itself, everything comes without comment and is ready to deploy.
