geological cross section
3038
7
09-26-2016 02:20 AM
MaximeGuillois
HI everybody,
I have a soil classification (raster ans shapefile), and topographic cross section made from a DEM.
I would like to ''colorize'' the cross section depending on the classification. to summarize I want to visualize on the cross section the soil occupation.
is it possible ?
Many thanks
Maxime G.
Bryan_Allan_M_Talisay
mhmhmp., this could be viewed through arcscene..
DanPatterson_Retired
If you can create polygons from the cross-section then that would be easy.  If your cross-section consists or raster or vector lines, then they would have to be closed to form either polygons or raster zones.
A picture of what you have would help
check the code sharing site eg.  http://www.arcgis.com/home/item.html?id=e86077dc453e4152a14c2e861de7fc01
MaximeGuillois
I have :
- a DEM
- Polygones files, with a field depending of the soil occupation on the attibute table
- A polyline where I want to have my cross section
- then, with the 3D analyst toolbar I've mad the cross section according to the elevation of the DEM
well you can't make that profile into a colorized depth plot... look at the tool that does cross-sections or examine the options on the code sharing site
MaximeGuillois
Thank you for your help,
I will check then come back to update this post
Cross section clip with each soil classification
It is possible when doing clip using vector layers...
MaximeGuillois
This is top view but is it possible to see as a topographic cross section ?
