Save Pro project (APRX) to AGOL or Portal?
2125
09-26-2016 02:55 PM
DennisGeasan
Occasional Contributor II
Is it possible to save an ArcGIS Pro project to either ArcGIS Online (AGOL) or Portal?  Can't see how to do it.  The Open Project dialog implies that it is possible to open a project from either AGOL or Portal.  However, when I try "Save As", the only option is to save to a local folder on the laptop.
AdrianWelsh
MVP Honored Contributor
Hi Dennis,
Follow the instructions here on how to do this:
Share a web map—ArcGIS Pro | ArcGIS for Desktop
DennisGeasan
That is for sharing a web map.  I want to save the ArcGIS Pro project file that has the extension "APRX".  It appears this can only be saved to the file system on your local computer.  But as I said, the ArcGIS Pro Open Project dialog allows you to browse to either AGOL or Portal implying I could open a project file from those locations.  But I can't see how to get a project saved to those systems.
AdrianWelsh
Dennis,
It looks like you can only use a Project Package in places like Portal (.ppkx), not a full project (.aprx). To use a project package, see the instructions here:
Package Project—Data Management toolbox | ArcGIS for Desktop
Once you have made your project into a project package, then you can upload it to portal.
