Geoform numerical default values
1211
09-27-2016 03:18 PM
AaronCraig2
I cant get the default numerical values to appear on my Geoform. What gives? Is this an oversight or a technical limitation?
Aaron
AaronCraig2
I should clarify that when I appear on the GeoForm, I mean appear in the boxes on the geoform. The values are there in the background and if you submit an entry without entering any information in to the boxes.
ArleneGuest
Did you figure this out?  I know how to do it if we could access the form's html code.  I also want to do something similar which is make a pulldown menu of choices for the user for one of the fields.  I saw this in one of the templates but there doesn't seem to be an option for creating this.  Any ideas?
AaronCraig2
Hi Arlene,
I just used hints to sort of spoof the user to thinking they needed to enter a value. If I remeber correctly, if no value is input on the form then the default value is used when submitted.
