Network Analysis
1266
10-02-2016 02:42 AM
AnandRao
I have two feature classes - Bus Route and Bus Stops. Bus Route has Route Name information and Bus Stops have Stop Number and Route Name information.  I would like to use these two feature classes to find out the below
  1. Distance between two stops irrespective of Route Name
  2. Shortest route between two stops based on the available Bus Routes
Please advise.
Regards
Anand
Tags (1)
DanPatterson_Retired
very possible.  The help topics are extensive and cover the necessary procedures to implement, once you know how to set everything up
Network analyst
Tutorial for beginners
MelindaMorang
Actually, since you already know the routes between the stops, this sounds like a problem you can solve with linear referencing.  You can use the linear referencing tools, or if you're comfortable with python, you can grab the geometry objects of your stops and routes and use the measureOnLine method.
