Negative scene rotation is not allowed?
1092
10-03-2016 12:42 AM
ÁkosHalmai
Occasional Contributor II
There is a “Rotation” property on the “General” tab, on the “Map Properties” of a local scene in ArcGIS Pro 1.3.1. This value expresses the rotation of the whole scene. If I rotate the scene manually it changes on the following interval: ]-180; +180]. However I can’t enter negative values. Only positives are allowed. For example the rotation value says that the scene is standing on -26.5°and I want to enter manually -25° than I can’t. Then I have to calculate that -25°equals to +335°. And after pressing the enter I see -25° again . It’s tiring.
DanPatterson_Retired
I would report it as a 'bug' or 'issue' in the documentation, one-way or another.  It won't get addressed if reported here, unless you have completely misinterpreted the description.
