CAD/GIS Webinar Qs: 3) Can you post and share the exact process on how to edit the .prj file to allow for reprojection into ArcGIS?
1060
10-03-2016 12:20 PM
ShannonValdizon
AdrianWelsh
MVP Honored Contributor
Just jumping in here... Is there a way to link to the webinar that you are mentioning? Or is it a private thing?
ShannonValdizon
Recording to the "CAD/GIS Integration and Workflows" webinar can be found here: Esri Department of Transportation Webinar Series
EricRodenberg
Create a CAD file Directory,  inside create a folder for each projected zone in your state.  Then take the ".prj" files for each zone and place them in the corresponding folder.  Rename the file esri_cad.prj.  For example in Ohio there are 2 state plane zones.  Ohio Stateplane NAD 83 North and Ohio Stateplane NAD 83 South I’ve attached a zip file with an example of how the folders should be organized.  Then place the CAD files that correspond to each zone in their proper zone folder.
Eric J. Rodenberg | Solution Engineer Transportation Practice
Esri | 7775 Walton Pkwy, Suite 270 | New Albany, Ohio 43054-8202 | USA
T 614-933-8698, ext. 5503 | erodenberg@esri.com | esri.com
