flex viewer shapefiles
1745
13
10-04-2016 12:12 PM
RamonCoello
how to load shapefiles to flex viewer? Thx
RamonCoello
Thank you! I am not sure where to place files, I placed them in widget folder, but it is not displaying in viewer.
RobertScheitlin__GISP
RamonCoello
Ramon,
   Read the readme.txt file for info on how the widget works.
RamonCoello
I added compiled version to shapefile and modified the config.xml  and I receive the following error.
the compiled version resides in C:\Program Files (x86)\ArcGIS Viewer for Flex\flexviewer\widgets
config.xml resides in C:\Program Files (x86)\ArcGIS Viewer for Flex\flexviewer
Thank you for your help! : )
<?xml version="1.0"?>
// Read more about ArcGIS Viewer for Flex - http://links.esri.com/flexviewer
<configuration>
<title>ArcGIS Viewer for Flex</title>
<logo>assets/images/logo.png</logo>
<style>
<colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>
<alpha>0.8</alpha>
</style>
<!-- replace the following url with your own geometryservice -->
<geometryservice
url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
<widget
left="10" top="50"
config="widgets/Navigation/NavigationWidget.xml"
url="widgets/Navigation/NavigationWidget.swf"/>
<widget
right="0" bottom="0"
config="widgets/OverviewMap/OverviewMapWidget.xml"
url="widgets/OverviewMap/OverviewMapWidget.swf"/>
<widget
right="20" top="55"
config="widgets/MapSwitcher/MapSwitcherWidget.xml"
url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
<widget
left="0" top="0"
config="widgets/HeaderController/HeaderControllerWidget.xml"
url="widgets/HeaderController/HeaderControllerWidget.swf"/>
<widget
label="Load Shape Files" x="400" y="60"
icon="widgets/ShapeFiles/assets/images/shapefiles.png"
config="widgets/ShapeFiles/ShapeFilesWidget.xml"
url="widgets/ShapeFiles/ShapeFilesWidget.swf"/>
<map
top="40"
wraparound180="true"
addarcgisbasemaps="true"/>
<widgetcontainer layout="float">
<widget
icon="assets/images/i_draw2.png"
label="Draw"
config="widgets/Draw/DrawWidget.xml"
url="widgets/Draw/DrawWidget.swf"/>
<widget
icon="assets/images/i_print.png"
label="Print"
config="widgets/Print/PrintWidget.xml"
url="widgets/Print/PrintWidget.swf"/>
</widgetcontainer>
</configuration>
Ramon,
   Did you follow the instructions for add a custom widget from the help?
ArcGIS Viewer for Flex | Manage Custom Widgets
Make sure you use the zip file in the For_AppBuilder3.7 folder and that you are using App Builder version 3.7 too.
RamonCoello
Thanks for your help! Robert I was able to upload zip file through manage custom widgets. So I guess there was no reason to modify config file ?
Although I find it takes forever to load a 78mb shapefile.
Ramon,
No
To be expected. This is not desktop where you have access to your full memory.
Don't forget to mark this thread as answered by click the "Correct answer" link on the reply that answered your question.
RamonCoello
I have tried to run to upload shapefile for hours and it will not load. File is huge, 78mb. is this too big to handle?
I closed error and it attempted to load, but it just display msg loading  shapefile .
Ramon,
  That size file is pushing the limits on what the browser plugin is capable of handling.
