How to remove/update maps in Compare Analysis template?
556
10-06-2016 06:55 AM
C_EHoward
Occasional Contributor III
How can I replace and/or delete maps in the Compare template that is on AGOL? The app states "Use the Select Web Map(s) button to select or change the webmap used in the application" but there is no ability to do so. I can add more but not take away. Only way I have been able to do this is to start another app from scratch. What am I missing? thanks
C_EHoward
I got it - you have to navigate through all of your content to deselect--- I had hoped you would be able to toggle on/off at the list and not through the entire content library. disregard
C_EHoward
