How to make a template (.xml) from Network Dataset
1707
10-10-2016 08:10 AM
MohsenZare1
I'm trying to create a template (.xml) from a network dataset. However apparently the tool is not available but the online ESRI help has code samples. I was wondering if anyone has had the same issue. On a side note all the ArcGIS help is on GIS Pro. Does this mean the tool is only available to GIS pro users? I'm using Arcmap 10.2.
THe code is as below:
import arcpy
from arcpy import env
arcpy.CheckOutExtension("Network")
myPath = r"C:\Users\za\Desktop\TT"
env.workspace = myPath + r"\Tt_Home.gdb"
inNetwork = r"\NetworkDataset\NetworkDataset_New"
output_xml = myPath + "/myTemplate.xml"
inNetwork arcpy.na.CreateTemplateFromNetworkDataset(inNetwork, output_xml)
The error I get is as below:
AttributeError: 'module' object has no attribute 'CreateTemplateFromNetworkDataset'
MelindaMorang
Yes, this tool is only available in ArcGIS Pro.  It is not available in ArcMap.
Documentation/help for the latest version of ArcMap is available here: ArcMap | ArcGIS for Desktop
Documentation for ArcMap 10.2 is here: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
MelindaMorang
Update: This tool is available in ArcMap as of the 10.6 release.
