Add eSearch Widget for WAB
2819
32
10-11-2016 04:36 AM
amalhorchi1
Hi Robert .
I am trying to add your eSearch custom widget to the Developer Edition of the Web AppBuilder 2.1 .
Whenever I run the eSearch Widget, I can't add a search layer .It is blocked .
RobertScheitlin__GISP
Amal,
   For some reason the escape character \ is not working for you. So you need to search and replace the \' characters with a blank or nothing in your D:\arcggis-web-appbuilder-2.1\WebAppBuilderForArcGIS\server\apps\18\widgets\eSearch\settings\nls\fr\strings.js
Amal,
   What do you mean by blocked? Can you share a screenshot?
amalhorchi1
Amal,
  Is there an error in your browsers web console (F12) when you click the add search layer link?
amalhorchi1
amalhorchi1
Amal,
   That error tells be that you are using a older version of the eSearch in your app as that french string error was fixed already. Be sure to download and use eSearch 2.1.2.
amalhorchi1
I have used esearch 2.1.2
amalhorchi1
Amal,
  If you had an older version of the eSearch widget in your WAB app then the way to update it to the latest version is to replace the eSearch folder in the apps directory (i.e. [install dir]\server\apps\[app #]\widgets\eSearch)
