Survey123 Read Only fields
2247
10-11-2016 08:44 AM
BBulla
I'm creating a Survey123 form using Survey123 Connect.  One of my fields gets populated through the URL like this:
arcgis-survey123://?itemID=...blahblahblah...&field:FACILITYID={FACILITYID}
I do not want a user to change what is getting populated in the FACILITYID field, so I change the READONLY attribute in the Survey123 form to 'yes', but once I do that the field disappears altogether and all I can see is the Label for the field.
What am I doing wrong??
LAG155
New Contributor III
Tengo el mismo problema, pero he visto que solo sucede con los campos que son texto
