How to display a million points on the map, defined by latitude and longitude.
2375
8
10-16-2016 03:16 AM
TMPTMP1
In swing java
Tags (4)
BatbayarBazarragchaa
New Contributor III
You had memory or performance issues displaying millions of points?
You can use GraphicLayer to display data with latitude and longitude.
// construct spatial reference
SpatialReference spatialReference = SpatialReference.create(102100)
// construct symbol
MarkerSymbol markerSymbol = new PictureMarkerSymbol(ImageLoader.loadImage("icons/triange_red.png"));
for (int i = 0; i < points; i++) {
   Point point = GeometryEngine.project(longitude, latitude, spatialReference);
   graphicsLayer.addGraphic(new Graphic(point, markerSymbol));
DanPatterson_Retired
If you need a visual representation, can you explain how you expect them to be distinguishable from one another?
TMPTMP1
Something like this.
I would probably summarize the points based upon the underlying polygons, then return the centroid of that polygon with the count of the points attributed to each polygon used to symbolize the point.  I presume that the image on the right wasn't done that way in an Arc* environment?
TMPTMP1
No.
I try it
don't know about your need to do this in your environment, but ArcMap has tools to help in the aggregation of points based on distance... Aggregate Points—Help | ArcGIS for Desktop
AlexanderNohe1
Occasional Contributor III
I moved this from the Android location to the Java location as Swing is a Java technology.
New Contributor III
// construct symbol
TMPTMP1
Performance issue,
Thanks for your answer.
