Access to portal using Credentials
1994
10-17-2016 05:35 AM
AntonioFiume
New Contributor III
Dear All,
i'm using the code present in the ArcGIS Runtime SDK for iOS (Quartz Beta) to connect to the portal:
var portal:AGSPortal!
self.portal = AGSPortal(URL: NSURL(string: "http://www.arcgis.com")!, loginRequired: false)
self.portal.credential = AGSCredential(user: "username", password: "password")
self.portal.loadWithCompletion() {[weak self] (error) in
if error == nil {
  // check the portal item loaded and print the modified date
  if self?.portal.loadStatus == AGSLoadStatus.Loaded {
   let user = self?.portal.user
   print(user?.fullName)
if i inserts wrong credential, the system shows ever a default popup to insert the credential (see attachment):
Is possible to manage the login error with a custom code?
In the previous SDK was present a portal delegate "didFailToLoadWithError" to manage the error.
In the code present in the example about Quartz SDK, seems that the code "if error..." is not execute because the systems shows the popup attached.
Is possible to hide the default popup how the previous SDK and manage all errors by code?
Thanks in advance!
Tony
YueWu1
by Esri Regular Contributor
Hi Antonio,
Sounds like you need to take a look about this AGSAuthenticationManager Class Reference
By default, Runtime iOS SDK will use the default AuthenticationViewController to manager those authentication. Since you mentioned that you need some custom code to handle those wrong credentials, you should utilize this AGSAuthenticationManager class, <AGSAuthenticationManagerDelegate> Protocol Reference
 var item: AGSPortalItem?
    var itemArray:NSMutableArray? = NSMutableArray()
    var authenticationManager: AGSAuthenticationManager = AGSAuthenticationManager.sharedAuthenticationManager()
    var portalItemID = String()
    let portal = AGSPortal(URL: NSURL(string: "http://www.arcgis.com")!, loginRequired: true)
    let map = AGSMap()
    override func viewDidLoad() {
        super.viewDidLoad()
        self.authenticationManager.delegate = self
        self.tags.append("Bingmaps")
        self.portal.credential = AGSCredential(user: "***", password: "***")
        self.portal.loadWithCompletion { [weak self](error) -> Void in
    func authenticationManager(authenticationManager: AGSAuthenticationManager,
    didReceiveAuthenticationChallenge challenge: AGSAuthenticationChallenge) {
        print("This will triggered when recevive authentication Challenge")
    wantsToDismissViewController viewController: UIViewController) {
        print("This will triggered when dismiss the provided view controller ")
    wantsToShowViewController viewController: UIViewController) {
        print("This will triggered when show the provided view controller")
Also, feel free to take a look about this github sample: QuartzSecurity: An iOS app demonstrating how to use Quartz runtime security services.
YueWu1
Hi Antonio,
    let map = AGSMap()
        super.viewDidLoad()
AntonioFiume
New Contributor III
Really really thanks!!
It would be impossible for me to found this way!
When i inserts the didReceiveAuthenticationChallenge the default login message now is disappear
Please note that i inserts the  challenge.cancel() code in the function to work fine more time usert tried to login with wrong credential:
func authenticationManager(_ authenticationManager: AGSAuthenticationManager,   didReceive challenge: AGSAuthenticationChallenge) {
       //Important to work fine when retry to login more time
        challenge.cancel();
Really thanks again Yue!
