I have a rest service url which I have used to create dynamic service and added it to the map. I want to loop through the arcgis dynamic map service layer to access feature layers in it.Is there any way to access feature layers in arcgis dynamic layer ?
I think I have found a solution to my problem. I am using the following to get details of a feature layer from ArcGISDynamicServiceMapLayer and applying the required query definition to it.
ArcGISDynamicMapServiceLayer dynamicLayer=myMap.Layers["myDynamicLayer"] as ArcGISDynamicMapServiceLayer;
string query="";
dynamicLayer.GetDetails(layerID,(ESRI.ArcGIS.Client.FeatuerService.FeatureLayerInfo myFeatureLayer,Exception ex) => {
if(ex == null)
query=myFeatureLayer.DefinitionExpression;
System.Collections.ObjectModel.ObservableCollection<LayerDefination> definitionCollection = new System.Collections.ObjectModel.ObservableCollection<LayerDefination>();
LayerDefinition layerDef=new LayerDefinition();
layerDef.ID=layerID;
layerDef.Definition=query+" AND Count > 100";
definitionCollection.Add(layerDef);
dynamicLayer.LayerDefinitions=definitionCollection;
dynamicLayer.Refresh();
Source: silverlight api reference
