WMS PopUp identify
3076
10-18-2016 07:11 PM
AhmadSopian1
Whether currently existing managed to identify wms????
RobertScheitlin__GISP
Ahmad,
   No there is no ability in Flex to identify WMS. Also the ArcGIS API for Flex is in mature status meaning it is a dead/dying technology. You should start looking at the JS API.
Carlos_CesarLanzoni
Limitations of OGC layers, like WMS
http://server.arcgis.com/en/portal/10.5/use/ogc.htm
  • You cannot edit features or add token-based secure OGC layers.
  • If the portal website is installed on the same network as an OGC WMS layer, the OGC WMS layer will be accessible in the map viewer and the website (WMS only); otherwise, internal OGC WMS layers are not supported.
  • Your OGC layer and basemap need to use the same coordinate system, for example, Web Mercator (the coordinate system of the default basemaps in the map viewer basemap gallery). Your portal administrator may have changed the default basemaps. Check with your administrator if you have issues using the map viewer's basemaps with your OGC layer.
  • OGC WMS group layers are not supported.
  • Refresh on OGC WMS layers only works if the WMS service honors standard HTTP caching rules.
  • If the option to configure pop-ups is not available for the WMS layer, you may need to add the layer to the map viewer again or re-create the WMS item. Some WMS layers do not support pop-ups.
  • When printing OGC WMS or WMTS layers, custom parameters are not supported.
