SDE 10 Upgrade Fails:ORA-29855: error occurred in the execution of ODCIINDEXCREATE
3799
12-14-2010 11:54 AM
DennisH
Can anyone help me with the following error that I'm getting when attempting to upgrade to ArcSDE 10:
Executing: UpgradeGDB "Database Connections\SDE_DC.sde" NO_PREREQUISITE_CHECK UPGRADE
Start Time: Tue Dec 14 14:27:27 2010
Paused the database for upgrade.
There are no other active connections.
User has privileges required to upgrade.
Connected RDBMS instance is not setup for ST_GEOMETRY configuration. [Unable to determine current version of ST_SHAPELIB
The latest ST_GEOMETRY and dependent libraries need
to be copied to the correct software location.
Please consult ArcSDE for Oracle Installation Guide
for further details.
Could not upgrade multiple schema or database instance. [The master geodatabase contains user schema geodatabases which should be upgraded separately after the master geodatabase is upgraded.
Id Version Instance
1 9.3.0 SDE_QC
Running Pre-Requisite check (C:\ESRI\Desktop10.0\ArcCatalog\SDE_DC.sde).
Instance supports XML type.
ArcSDE server tables and stored procedures are up to date.
Underlying DBMS error [Layer not found] [Error executing PL/SQL Block db_stgeom_create_index
ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine
ORA-04063: package body "SDE.SPX_UTIL" has errors
ORA-06508: PL/SQL: could not find program unit being called: "SDE.SPX_UTIL"] Underlying DBMS error [Error executing PL/SQL Block db_stgeom_create_index
Unpaused the database.
Failed to execute (UpgradeGDB).
Failed at Tue Dec 14 14:27:39 2010 (Elapsed Time: 12.00 seconds)
DennisH
Attached log file.
Also after each unsuccessful attempt the following three packages become invalid:
spx_util
st_relation_operators
st_type_export
I am able to re-compile them without any issues.
DennisH
I was able to resolve the issue by recreating the SDE.SPX_UTIL and rerunning the upgrade process.
OvidioRivero
New Contributor III
How did you recreate this package?  I am having a simillar problem not upgrading but loading a new feature class on the database ad it fails with the same error. I went into the sde tables and the package is compiled with errors.  I tried recompiling and it shows errors again.
