Hosted feature service is not visible from javascript api
1198
5
10-20-2016 04:50 AM
SOVANHALDER
New Contributor III
I have one hosted feature service on ArcGIS Online organizational account and it is shared with everyone. When I am trying to access this featurelayer from a javascript api the layer is not visible. Kindly help
KenBuja
MVP Esteemed Contributor
Please post your code to show how you are attempting to access the feature service.
SOVANHALDER
New Contributor III
Hi It is working after changing to https:// from http://
BillChappell
Occasional Contributor II
I think your center coordinates are off. Try  center: [76.641536,12.316173],
This worked for me:
require([
    "esri/map",
    "esri/layers/FeatureLayer",
    "dojo/domReady!"
  function(
    Map,
    FeatureLayer
    var map = new Map("map", {
      basemap: "hybrid",
      zoom: 10
     * Add feature layer - A FeatureLayer at minimum should point
     * to a URL to a feature service or point to a feature collection
     * object.
    // Carbon storage of trees in Warren Wilson College.
    var featureLayer = new FeatureLayer("http://services1.arcgis.com/ECFqcT5baCSej64y/ArcGIS/rest/services/mysore1/FeatureServer/0");
    map.addLayer(featureLayer);
BillChappell
Tough to see but there are 4 orange dots, may be easier to see if you turn basemap to streets.
KenBuja
You could also set the extent of the map from the feature layer itself, like in this example
JS Bin - Collaborative JavaScript Debugging
