I have a table in SDE,the table is not a FeatureLayer,how can I get the rows of the talbes by arcgis api for javascript 3.18?
1189
10-20-2016 07:44 PM
shaoyunpengshao
RobertScheitlin__GISP
JS is a client side technology and does not have the ability to access the database without the use of ArcGIS and a rest endpoint. If you publish the table to ArcGIS Server then you will be able to access it from JS API and do a record count query.
shaoyunpengshao
thank you for your answer.it's helpful for me.thanks again!
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
SteveCole
The way I have done this in the past is to include the SDE table inside the MXD of another layer you need to publish. The standalone table will now be published as a layer inside the service that you can query using queryTask, etc.
