Basemap Gallery Widget Issue
1357
5
10-20-2016 01:54 PM
LloydBronn
Occasional Contributor II
I'm using the basemap gallery widget in my maps. I've noticed that when I choose a different basemap, the reference from the default basemap (grey) is still in the map. As a result, I see city names doubled up on each other. Is there a way to clear the reference from the default basemap when a user chooses a new basemap?
RobertScheitlin__GISP
Lloyd,
OK that seems to be a bug.  Here is a workaround if you are going to use a basemap like gray that has a reference layer to initialize the map:
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>Basemap gallery</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
  <style>
    html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    #map{
      padding:0;
  </style>
  <script src="https://js.arcgis.com/3.18/"></script>
  <script>
    var map, refLayerId;
    require([
      "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
      "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery, arcgisUtils,
      parser
      parser.parse();
      map = new Map("map", {
        basemap: "gray",
        center: [-105.255, 40.022],
        zoom: 13
      //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
      var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      basemapGallery.on("selection-change",function(){
        var layer = map.getLayer(refLayerId);
        if(layer){
          map.removeLayer(layer);
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
      basemapGallery.on("load", function(msg) {
        for (b=0;b<map.basemapLayerIds.length;b++){
          var lyr = map.getLayer(map.basemapLayerIds[b]);
          if(lyr._isRefLayer){
            refLayerId = lyr.id;
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style="width:100%;height:100%;margin:0;">
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'"
         style="padding:0;">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap', closable:false, open:false">
          <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
            <div id="basemapGallery"></div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Lloyd,
   I do not see this issue when using the basemap gallery sample
Basemap gallery | ArcGIS API for JavaScript 3.18
So it must be something in your code.
LloydBronn
If you change the default basemap on the sample to "gray" and then change the basemap, you'll see what I mean. The label for Boulder is doubled up. It think it might be an issue with the light gray canvas basemap.
Lloyd,
<!DOCTYPE html>
<html>
<head>
  <style>
    #map{
      padding:0;
  </style>
  <script>
    require([
      "dojo/parser",
      "dojo/domReady!"
    ], function(
      parser
      parser.parse();
        basemap: "gray",
        zoom: 13
        map: map
        if(layer){
  </script>
</head>
    <div id="map"
         style="padding:0;">
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
LloydBronn
Thanks! Can we report this bug to ESRI?
KenBuja
MVP Esteemed Contributor
This has been report as BUG-000089550. I came across this issue last year: Bug in Basemap Gallery dijit
With a little more searching, it turns out this has been an issue for a while longer. NIM089693: If the BasemapGallery widget is initialized with a b..
It's a pity they don't plan to fix it.
