Edit Widget and vertices
3157
5
10-20-2016 07:59 AM
SebastienPelletier
I added the edit widget in my application and it's not able to edit the vertices. By cons in the API Javacript if I double click on a feature that is possible.
https://developers.arcgis.com/javascript/3/samples/ed_simpletoolbar/
SebastienPelletier
I modified the widget to ensure editing vertices. In  "bindEventsAfterCreate" function I added this:
this.own(on(this.editor.editToolbar,
   'activate',
   lang.hitch(this, function (evt) {
   if (evt.tool != 31) {
      this.editor.editToolbar.activate(1 | 2 | 4 | 8 | 16, evt.graphic);
Now I can edit vertices 🙂
RobertScheitlin__GISP
Sebastien,
  Make sure that you have enabled vertex editing (Reshape) in the widgets settings and that FeatureService allows geometry updates.
SebastienPelletier
All is activate ( I can use the reshape tool), I also tested a webapp created in Online and is the same conclusion. Are you able to do it in your applications?
DerekLaw
Esri Esteemed Contributor
Hi Sebastien,
In the Smart Editor widget, after you select a feature, in the pop-up for attribute editing, ensure you've checked the "Edit Geometry" option in the dialog. This should enable editing vertices.
Smart Editor Widget - editing vertices
Hope this helps,
SebastienPelletier
SebastienPelletier
   'activate',
