Update old version of LGM to latest version
796
10-21-2016 08:49 AM
MatthewParsell
I am wondering if anyone has found a good solution to updating their LGM database to the latest version?  I attempted to do the workflow suggested by ESRI found here Upgrade information model - Local Government Information Model | ArcGIS for Local Government .  The issue is the data migration wizard they suggested seems to be out of date as it does not have the latest version to compare to June 2016, and on top of that after I run the wizard when trying to import the xml generated by the wizard into a new geodatabase when it reaches the feature class wControlValve I recieve this error "Import xml data failed / The item was not found. The item was not found."  If I remove wControlValve it gives the same error when it reaches the next feature class in line.
