Find a text inside a feature class
895
10-24-2016 05:46 AM
DharmaRajan
I want to retrieve the records having a text inside the feature class irrespective of field name using Arcobjects.
JaredCaccamo
This would be how you verify the field type to be a text(string). Related samples are at the bottom. http://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#IField_Type.htm
Best of luck,
Jared
CarstenSchumann
Simply loop all fields of all records from your table:
IEnumerable<IFeature> GetFeaturesBySearchValue(object searchValue)
    var featureClass = myWorkspace.OpenFeatureClass(fcName);
    var cursor = featureClass.Search(null, true);
    var fields = featureClass.Fields;
    IFeature feature;
    while((feature = cursor.NextFeature()) != null)
        for (int i = 0; i <= fields.FieldCount - 1; i++)
            var theValue = feature.get_Value(i);
            if (theValue == searchValue) yield return feature;
Be aware to also release the features and the cursor when you´re done with them.
