Change map cursor when over a feature
3294
10-24-2016 04:39 PM
StevenPaplanus
New Contributor III
I have a web map where I have a base layer with the states, and a feature layer with several dozen polygons.  I have set the identity function (which for this app is always on for a single click)  to use the feature layer.   I am wondering if it is possible to detect when there is a feature that the cursor is going over, and then change it to indicate there is data on it, and when the user moves off of the feature, and there is nothing there, it changes back to the default cursor.
RobertScheitlin__GISP
Steven,
  Sure here is a sample that shows that:
<!DOCTYPE html>
<html>
  <head>
    <title>Feature Layer - display results as an InfoWindow onHover</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
      #mapDiv {
        position: relative;
      #info {
        background: #fff;
        box-shadow: 0 0 5px #888;
        left: 1em;
        padding: 0.5em;
        position: absolute;
        top: 1em;
        z-index: 40;
    </style>
    <script src="https://js.arcgis.com/3.18/"></script>
    <script>
      var map, dialog;
      require([
        "esri/map", "esri/layers/FeatureLayer",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/renderers/SimpleRenderer", "esri/graphic", "esri/lang",
        "esri/Color", "dojo/number", "dojo/dom-style",
        "dijit/TooltipDialog", "dijit/popup", "dojo/domReady!"
      ], function(
        Map, FeatureLayer,
        SimpleFillSymbol, SimpleLineSymbol,
        SimpleRenderer, Graphic, esriLang,
        Color, number, domStyle,
        TooltipDialog, dijitPopup
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-80.94, 33.646],
          zoom: 8,
          slider: false
        var southCarolinaCounties = new FeatureLayer("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3", {
          mode: FeatureLayer.MODE_SNAPSHOT,
          outFields: ["NAME", "POP2000", "POP2007", "POP00_SQMI", "POP07_SQMI"]
        southCarolinaCounties.setDefinitionExpression("STATE_NAME = 'South Carolina'");
        var symbol = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_SOLID,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([255,255,255,0.35]),
          new Color([125,125,125,0.35])
        southCarolinaCounties.setRenderer(new SimpleRenderer(symbol));
        map.addLayer(southCarolinaCounties);
        map.infoWindow.resize(245,125);
        dialog = new TooltipDialog({
          style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100"
        dialog.startup();
        var highlightSymbol = new SimpleFillSymbol(
            new Color([255,0,0]), 3
        //close the dialog when the mouse leaves the highlight graphic
        map.on("load", function(){
          map.graphics.enableMouseEvents();
          map.graphics.on("mouse-out", closeDialog);
        //listen for when the onMouseOver event fires on the countiesGraphicsLayer
        //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer
        southCarolinaCounties.on("mouse-over", function(evt){
          map.setMapCursor("pointer");
          var t = "<b>${NAME}</b><hr><b>2000 Population: </b>${POP2000:NumberFormat}<br>"
            + "<b>2000 Population per Sq. Mi.: </b>${POP00_SQMI:NumberFormat}<br>"
            + "<b>2007 Population: </b>${POP2007:NumberFormat}<br>"
            + "<b>2007 Population per Sq. Mi.: </b>${POP07_SQMI:NumberFormat}";
          var content = esriLang.substitute(evt.graphic.attributes,t);
          var highlightGraphic = new Graphic(evt.graphic.geometry,highlightSymbol);
          map.graphics.add(highlightGraphic);
          dialog.setContent(content);
          domStyle.set(dialog.domNode, "opacity", 0.85);
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
        function closeDialog() {
          map.setMapCursor("default");
          map.graphics.clear();
          dijitPopup.close(dialog);
    </script>
  </head>
  <body class="tundra">
    <div id="mapDiv">
      <div id="info">
        Hover over a county in South Carolina to get more information.
      </div>
    </div>
  </body>
</html>
Steven,
<!DOCTYPE html>
<html>
  <head>
    <style>
        padding:0;
        margin:0;
        height:100%;
      #mapDiv {
        position: relative;
      #info {
        background: #fff;
        left: 1em;
        padding: 0.5em;
        position: absolute;
        top: 1em;
        z-index: 40;
    </style>
    <script>
      var map, dialog;
      require([
      ], function(
        Map, FeatureLayer,
          basemap: "streets",
          zoom: 8,
          slider: false
        dialog.startup();
          dijitPopup.open({
            popup: dialog,
            x: evt.pageX,
            y: evt.pageY
    </script>
  </head>
    <div id="mapDiv">
      <div id="info">
      </div>
    </div>
  </body>
</html>
Arne_Gelfert
Occasional Contributor III
Just what I needed. As someone who is constantly learning new Javascript stuff and API hacks at the same time, I was playing with ...
document.getElementById("myElement").style.cursor = "<pointer-style>";‍‍
But the above did the trick for me!
