Dear All,
Please can anyone tell me what DBMS to use for values with range keeping in mind that i will like to analyse these values.
i will appreciated appropriate suggestions.
(example 14.54 - 18.932)
thanks
Hi there,
Is this in the context of using the DBMS data with ArcGIS or something else? It might help if you could provide more context and details as to what exactly you want to do/what your workflow is.
For example, if you're asking what DBMS platforms we support for geodatabases (the spatial data model for ArcGIS), I would start here, What is a geodatabase?—ArcGIS Help | ArcGIS for Desktop
You could also work with data in a DBMS by using query layer functionality,
What is a query layer?—Help | ArcGIS for Desktop
Hope this helps,
Are you referring to Data type?
For decimal numbers, you can keep the data type as FLOAT or DOUBLE.
DBMS data types supported in ArcGIS—Help | ArcGIS for Desktop
