Could be MapBox Tileset used as a base map in ESRI webmap with JavaScript API?
1342
10-25-2016 02:41 PM
PitersonPaulgek
New Contributor III
Could be MapBox Tileset used as a basemap in ESRI webmap with JavaScript API?
What type of the layer/service could be used: Map service, Feature service any other for better performance?
Any help will be appreciated.
SethLewis1
Occasional Contributor III
Piterson,
It's possible to consume Mapbox tiles via the JS API in two ways: either as a VectorTileLayer and or as a WebTileLayer.
Generally speaking vector tiles perform better with newer hardware. As for supported layers, it's possible to add both map services and feature services while using a Mapbox basemap.
Are you able to provide sample code if you're experiencing issues?
SethLewis1
Piterson,
PitersonPaulgek
New Contributor III
Hi Seth,
Thank you for your response.
Just general possibility to use.
boeskmgmoes
Can you provide a public example of using this as a vectortilelayer?
