Excel XY Data to Shapefile
5537
18
10-26-2016 10:20 AM
VicenteSolis1
I have a question about Excel XY Data to Shapefile.  The Excel file I am working with has over 100,000 points, each with its own ID and lat/long.  When I convert the data to a shapefile, the shapefile does not show all information.  The data is crash data and for example, the IncidentID column's data is deleted when it converts to a shapefile.
Any ideas how to fix this?  Thank you.
DarrenWiens2
MVP Honored Contributor
Lots of potential problems, but most common is spaces or other special characters in field names. Remove them in Excel and try again.
VicenteSolis1
The column that is was talking about is labeled "IncidentID", no special characters in it.
DarrenWiens2
The field names must be good for all columns, not just the misbehaving one. In any case, see here for more: Formatting a table in Microsoft Excel for use in ArcGIS—Help | ArcGIS for Desktop
VicenteSolis1
Problem solved, got it to work by saving it as a CSV file.
VicenteSolis1
Darren,
I have another question now.  The CSV worked fine, a majority of data transferred without issue.  However, the data/time data didn't show up.  In Excel, the information is in m/d/yyyy h:mm.  Does GIS not accept this?
DarrenWiens2
Hmmm... shapefiles definitely don't support the time component of date/time, but I would have guessed that it could parse out the date component. Either try exporting the CSV point data as a GDB feature class (which do support date/time) or parse out the date in Excel and try again, exporting to shapefile.
edit: on second read, does the date/time not show in CSV file when you bring it into ArcMap?
DanPatterson_Retired
Assuming the information was transfered in the csv file properly, if the destination output file was to a shapefile, no... if it was to a geodatabase, yes... Check the help topics on date and time for your version of ArcMap
VicenteSolis1
It doesn't show, it shows as Null.
VicenteSolis1
I did transfer the point data straight to a geodatabase, that's where it showed up as Null.
