Link data view with layout
4085
5
10-27-2016 06:25 AM
LizDaRos
Having trouble trying to link my data view with the data map frame in the layout. I want to have the same extent and/or same center in the layout map frame as the data view. Kind of like how it works in ArcMap.
I've played around with the data frame display options and the constraint but nothing seems to work.
DanPatterson_Retired
You are talking about the first paragraph in this link
Add and modify map frames—Layouts | ArcGIS for Desktop
then see this link
Work with a map on a layout—Layouts | ArcGIS for Desktop
MaribethPrice
I think that the answer is, Pro is just different.  The map view extent and layout extent are purposely separated (which would be required if you had multiple layouts on the same map and wanted different extents.  To update the map extent in the layout, activate the map from within the layout, zoom/center.  When you close the activated map, the layout extent will be set and will not change when you zoom the map.
LizDaRos
Well that is unfortunate. Thank you both for your information!
ZacharyMiller
I do find it very frustrating that the layout extent apparently cannot be linked to the map extent.  I was looking forward to being able to have all my different figures as separate layouts so I don't need to change headers, sources, etc everytime I want to print a different figure.  I typically have the same 4 or 5 figures for every report, sometimes more. It really is a pain that I have to physically activate the map on each layout and navigate to the same view. It takes way too much time to attempt to match views and scales.
I can understand that sometimes people want different views on different layouts. What's so hard about being able to turn on and off a dynamic link between the map view and layout view?
DavidWatkins
Another option for you to try would be to set bookmarks for the different extents you want to use.  You can zoom to bookmarks for maps in layouts without having to activate the map frame and the bookmarks can be used in map views as well.
