Blob field not showing up in AGOL Map
1528
10-27-2016 11:24 AM
ChayaBalsiger
I created a comment field with the field type as Blob in the RoadBlock feature class that is the Local Government Model.  I gave it a length of 1500.  I needed to create this field because I need to add comments longer than 255 characters. I published the service, created an editing map in ArcGIS Online, added test data, typed information in the comment field (field type Blob), saved the map and then refreshed the map.  After I refresh the map, I check to see if all the data is there; everything shows up but what was written in the comment field.  Whatever I type into the comment field does not get saved like the other data does (date, name, reason type etc).  Does the blob field type not show up in ArcGIS Online?
MarkHoyland
Occasional Contributor II
Could you use a string field with a length of 1500 instead of blob? You can have string fields with that length.
MarkHoyland
ChayaBalsiger
That's what I did.  Now it works fine.
by Anonymous User
Not applicable
As Mark Hoyland states for this use case you would want to use a text field with a length of 1500. Blob fields store data in binary. Because blob fields store data in binary it would not be useful for storing comments which are intended to be readable by humans.
