Confused with ArcGIS Online Feature Layer (Hosted) and Feature Layer
1050
10-28-2016 09:18 AM
JoseSanchez
Occasional Contributor III
Good morning everyone,
I am currently testing AGOL web editing options pointing to a feature class located in ArcSDE.
I am trying to create a in AGOL Feature Layer pointing to a local ArcGIS Server feature service:
http://[myserver]:6080/arcgis/rest/services/[folder]/[service_name]/FeatureServer/0
From ArcGIS Online I go to MyContent --> Create --> Feature Layer.  To create a Feature Layer.
2 years ago I was able to create a Feature Layer and this feature layer was pointing to the service located in my server:
Now when I try to create the same Feature Layer, but this feature layer is called a  Feature Layer (Hosted).
http://services.arcgis.com/8Pc9XBTAsYuxx9Ny/arcgis/rest/services/[service_name]/FeatureServer
Was the option to create a Feature Layer pointing to a local ArcGIS Server Service disabled and replaced by Feature Layer (Hosted)?
Any advice will be welcome.
BlakeTerhune
MVP Regular Contributor
Esri's documentation says a hosted feature layer is a type of hosted web layer.
About hosted web layers—ArcGIS Online Help | ArcGIS
I think the "hosted" term is just to be more specific that it's something external from ArcGIS Online. This is probably just a change in naming compared to what you saw two years ago.
JoseSanchez
Found it:  instead of using the option Create a Feature Layer,  I used the option Add Item from the Web, and it also creates a Feature Layer but this time pointing to a local service
